The Allied Telesis' range of Fast Ethernet Media converters provides a complete series of conversion devices, allowing users to extend the size of UTP and multi-mode fiber networks with the use of single-mode fiber cabling. Supporting SC-connected single-mode fiber, these converters can be used to extend networks up to a distance of 2km.
All these media converters feature an internal MDI/MDIX switch, allowing the converter to be connected to PC, hub or switch with a simple UTP cable. The media converters also allow the installer to test the integrity of fiber connection, by forcing the converters to communicate over the fiber cable. This Link Test feature allows installers to check for cable faults without the need for expensive fiber optic test equipment.
- Allied Telesis AT MC102XL - fibre media converter - 100Mb LAN
- Fibre media converter - SC multi-mode / RJ-45
- Form Factor
- External
- Cabling Type
- 100Base-FX, 100Base-TX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- 10.5 cm x 9.5 cm x 2.5 cm
- 294 g
- Environmental Standards
- ENERGY STAR Qualified
- 5-year warranty
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 2 km
- Status Indicators
- Port duplex mode, power, link OK, test mode, link/activity
- Auto-negotiation, MissingLink, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- IEEE 802.1Q
- 1 x Ethernet 100Base-FX - SC multi-mode x 2 , 1 x Ethernet 100Base-TX - RJ-45
- FCC Class B certified, CSA, UL, TUV, cUL, RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- 10.5 cm
- 9.5 cm
- 2.5 cm
- 294 g
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 5 - 95%
