Allied Telesis' AT-2916SX is a high reliable 32-bit PCI Gigabit Fiber Adapter card. It helps to boost your Fast Ethernet desktop throughput ten times to 1000Mbps. With the 1000Base-SX fiber-optic connection, data transmission is both secure and faster.
In order to reduce CPU usage, Allied Telesis' AT-2916SX uses the adaptive interrupts and ultra-deep 96-KB packet buffer. Coupled with link aggregation and load balancing, AT-2916SX achieves the best performance of its class for server connectivity.
 - Allied Telesis AT-2916SX/SC - network adapter - PCI - 1000Base-SX
 - Network adapter
- Form Factor
 - Plug-in card
- Interface (Bus) Type
 - PCI
- PCI Specification Revision
 - PCI 2.2
- Ports
 - 1000Base-SX
 - 1.3 cm x 17.8 cm x 5.1 cm
 - 85 g
- Cabling Type
 - Ethernet 1000Base-SX
- Data Link Protocol
 - 1GbE
- Data Transfer Rate
 - 1 Gbps
 - TCP/IP, UDP/IP
 - IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1ab (LLDP)
- System Requirements
 - Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 2000 / XP, Linux 2.4.x
- Microsoft Certification
 - Works with Windows Vista
 - Network adapter
- Form Factor
 - Plug-in card
 - PCI
 - PCI 2.2
- Ports
 - 1000Base-SX
- Connectivity Technology
 - Wired
- Cabling Type
 - Gigabit Ethernet
 - 1 Gbps
 - TCP/IP, UDP/IP
- Status Indicators
 - Link OK, link/activity
 - Full duplex capability, ACPI support, auto-negotiation, remote reboot, VLAN support, WOL
 - 1 x 1000Base-SX - SC multi-mode - x 2
- Compatible Slots
 - 1 x PCI
 - Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
 - ACPI, FCC Class B certified, UL, VCCI, EN55022, RoHS
- Software Included
 - Drivers & Utilities
- OS Required
 - 1.3 cm
 - 17.8 cm
 - 5.1 cm
 - 85 g
 - 10 °C
 - 55 °C
 - 10 - 95%
