- Socket type - Intel LGA775, LGA1155, LGA1156, LGA1366 & LGA2011, AMD Socket AM2, AM2+, AM3, AM3+ & FM1.
- Heatsink material - 8 heatpipes, copper base, aluminium fins.
- Akasa Venom Medusa AK-CC4010HP01 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste, fan resistor cable, PWM fan adapter cable
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1
- Heatsink Material
- Aluminum with nickel plated copper base
- Fans Qty
- Dual
- Fan Diameter
- 120 mm/145 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydrodynamic bearing
- Rotation Speed
- 600-1600/1900 rpm
- Air Flow
- 83.6/109.5 cfm
- Noise Level
- 6.9 - 28.9/7 - 21.7 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support, S-FLOW blades, dual Viper fans
- 14.4 cm 16.3 cm
- 1.3 kg
- Noise reduction
- Product Type
- Processor cooler
- Package Content
- 14.4 cm
- 16.3 cm
- 1.3 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Heatsink Dimensions
- 163 mm x 144 mm x 129.5 mm
- Fans Qty
- 2
- Fan Diameter
- 120 mm/145 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 600-1600/1900 rpm
- Air Flow
- 83.6/109.5 cfm
- Air Pressure
- 2.91/2.98 mm
- Noise Level
- Power Connector
- Rated Voltage
- 12 V
- Mounting Kit
- Included
- Noise reduction
