An evolution in silicone technology delivers outstanding thermal performance. Pro-grade Silicone technology provides a stable thermal compound which delivers a great thermal performance. Minimized resistance and maximized efficiency truly enables you to get a lot more from your cooler. It's RoHS compliant.
- Akasa AK 460 - processor heatsink paste
- Product Type
- Processor heatsink paste
- Grey
- Product Material
- Silicone
- 4 g
- Product Type
- Product Material
- Silicone
- 4 g
- Grey
- -45 °C
- 200 °C
Customer reviews
Write a review for the Akasa Silicone Thermal compound, 3.5G with Spreader card here!
Rather big tube
Reviewed by Darren. Review Posted 01/12/2007
rather big tube compared to what im used to..
Anyways, it keeps my AMD Phantom 9500 at 40*C, so its good, but to be honest artic silver is better
Overall
Ease of use
Value for money
Buy this now!
Reviewed by Joe Gibbs. Review Posted 10/11/2006
This stuff is grey and pasty. A kind of grey paste. It cools your CPU! Don't get it on the carpet though...
Although I think £6 is a bit pricey for the tiny pot you get - it is an essential buy.
Overall
Ease of use
Value for money
What a result!!
Reviewed by Richard Todhunter. Review Posted 07/06/2007
Bought this to put on my cpu when changing motherboards. My cpu usually was about 45-50c Idle. With this stuff it is now 30-35c Idle!!
Can't ask for more than that!
Does exactly what it says on the.. small.. tube
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
