New Serial ATA revision 3.0 cables designed for ultra fast data transfer up to 6Gb/s. Third generation of SATA technology cables are compliant with new NCQ streaming for high quality audio and video. Straight to right angle connectors compatible with stacked SATA motherboard connectors. Rounded, aerodynamic shape for better airflow and sleek style. SATA 6GB/s cables are backwards compatible with SATA and SATA II devices. Available in two lengths: 50 and 100cm.
- SATA revision 3.0 supporting 1.5 / 3.0 and 6.0 Gb/s data transfer
- Straight 7-pin to right angle 7-pin with securing latch
- Compatible with stacked motherboard SATA connectors
- New NCQ streaming compliant for high quality audio and video
- Rounded aerodynamic cable aids airflow and adds style
Application : SATA data connection Design for: SATA hard drives and optical devices Length: 100cm Colour: Black Motherboard connector : Straight (7pin) HDD connector: Right angle with latch (7pin) Supported connections :SATA 1.5 / 3.0 / 6.0 Gb/s
