Extend the length of an ATX power supply connection by up to 8in. The ATX24POWEXT ATX 2.01 Power Extension Cable features one male and one female 24-pin ATX connector, enabling you to extend the length of an ATX power supply connection.
Providing 8-inches of cable length, the ATX24POWEXT allows you to position your internal components as needed within the system case without having to strain the ATX or motherboard connections.
- StarTech.com 8in 24 Pin ATX 2.01 Power Extension Cable - Power extension cable - 24 pin ATX (M) to 24 pin ATX (F) - 7.9 in - ATX24POWEXT - power extension cable - 24 pin ATX to 24 pin ATX - 20 cm
- Length
- 20 cm
- Connector
- Power 24 pin ATX - male
- Connector (Second End)
- Power 24 pin ATX - female
- Limited lifetime warranty
- Length
- 20 cm
- Connector
- FCC
