Akasa Nero LX 2 Multi Platform 120mm Heatpipe Cooler PWM Fan
Quicklinx: C1YWWS00 Mfr#: AK-CC4016EP01
  • Socket type: Intel LGA775, LGA115X & LGA1366
  • AMD Socket: AM2, AM2+, AM3, AM3+, FM1 & FM2
  • Heatsink material: Aluminium fins, copper heatpipes
  • Cooler weight: 282g
  • Cooler dimension: 120 x 120 x 57mm (W x D x H)
  • Fan dimension: 120 x 120 x 15mm
  • Fan speed: 600 - 1800 RPM
  • Max airflow: 61.37 CFM
  • Max air pressure: 1.72 mm H²O
  • Noise level: 32.9 dB(A)
  • Voltage rating: 12V DC
  • Bearing type: EBR
  • Fan connector: 4pin PWM
  • Product code: AK-CC4016EP01
Akasa NERO LX 2 - processor cooler
Processor cooler
Package Content
Washer, Heat Conduction Compound, screws, Intel mounting bracket, 5 rubber pads, bracket screws, spanner, AMD mounting bracket
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium and copper
Fan Diameter
120 mm
Fan Height
15 mm
Rotation Speed
600-1800 rpm
Air Flow
61.37 cfm
Noise Level
32.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
4 copper heatpipes
12 cm x 12 cm x 5.7 cm
282 g
Processor cooler
Package Content
12 cm
12 cm
5.7 cm
282 g
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
15 mm
Rotation Speed
600-1800 rpm
Air Flow
61.37 cfm
Air Pressure
1.72 mm
Noise Level
32.9 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
4 copper heatpipes
