It offers ultra compact and low noise cooler for Intel Core 2 Duo and Core i3 CPU's. The low profile design with embedded fan makes it a perfect solution for mini-ITX, HTPC and SFF systems.
Aluminum heat-sink and enter bearing fan ensure high efficiency and long life. High engineered multi directional aluminum heat-sink maximizes heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
- Akasa AK CC7122EP01 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Tool-less fixed pins
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 75 mm
- Fan Height
- 10 mm
- Fan Bearing
- EBR bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 23.5 cfm
- Noise Level
- 30.8 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Copper core heatsink
- 8.52 cm x 8.72 cm x 2.6 cm
- 152.8 g
- Product Type
- Processor cooler
- Package Content
- 8.52 cm
- 8.72 cm
- 2.6 cm
- 152.8 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core 2 Duo - all speeds , Core i3 - all speeds
- Heatsink Material
- Aluminium
- Fan Diameter
- 75 mm
- Fan Height
- 10 mm
- Fan Bearing
- EBR bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 23.5 cfm
- Air Pressure
- 1.81 mm
- Noise Level
- 30.8 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.19 A
- MTBF
- 40,000 hours
