Akasa Exhaust System Blower
Customer rating: 3.5* (Write a review)
Quicklinx: 303CWS00 Mfr#: AK-SB-BK
Akasa is the leader in thermal integration solutions. Basing on quality and consistency, Akasa continues to produce new and innovative components to excite the high end market.
Akasa AK SB-BK fan unit
Fan unit
Fan Bearing
Ball bearing
Rotation Speed
2000 rpm
Air Flow
35.1 cfm
Noise Level
25.2 dBA
Power Connector
4 pin Molex connector
2.2 cm x 10 cm x 9.1 cm
Fan unit
2.2 cm
10 cm
9.1 cm
Heatsink & Fan
Fan Bearing
Ball bearing
Rotation Speed
2000 rpm
Air Flow
35.1 cfm
Noise Level
25.2 dBA
Power Connector
Customer reviews
Write a review for the Akasa Exhaust System Blower here!
Quieter than expected
Reviewed by Simon. Review Posted 02/07/2008
I was pleasantly surprised to find that this blower is almost inaudible, having feared that it would sound like a jet engine like so many cheap fans. I've not been able to install it yet, but I've no doubt that it will do the job of cooling an otherwise fanless Geode-based PC with an overheating problem. Build quality is quite good considering the price.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very Good
Reviewed by Alex. Review Posted 17/08/2004
This is a very usfull device to have if you want a cool system, it was very easy to install and has remarkable build qaulity.
  • Overall 5*
  • Ease of use 5*
Quality, value, anything else you want?
Reviewed by David. Review Posted 10/09/2006
Fantastic exhaust fan. Does exactly what it sould with no fuss and fiddling. One reviewer states the card as noiy, nut if u are looking for silence, you should be buying heatsinks not fans! For £4 you cant go wrong, give it a try, it can drop ur temps a bit!
  • Overall 4*
  • Ease of use 5*
Read all 6 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
