- Ideal for business education and embedded environments
- Form factor: Mini-ITX 6.7" X 6.7"
- Bays: 2.5 HDD and slimline optical drive
- Audio and two USB ports for easy connectivity
- Compatible with all Mini-ITX motherboards
- Flex ATX power supply (optional)
- Motherboard support: Mini-ITX- Body material: Steel- External bays: 1 x 5.25" (for slim optical drive)
- Internal bays: 1 (for 2.5 HDD)
- Dimensions: 200(W) x 306(D) x 76(H)mm
- I/O ports: 2 x USB 2.0 1 x HD audio (AC97 compatible)
- PSU support: Flex ATX power supply
- Akasa Crypto X1 - SFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- I/O Connectors
- 2 x USB 2.0 , 2 x audio
- Supported Motherboards
- Mini-ITX
- Power Device
- Power supply 200 Watt (FlexATX)
- 20 cm x 30.6 cm x 7.6 cm
- Form Factor
- Small form factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 1
- Front Accessible Bays Qty
- 1
- Cooling System
- 60 x 60 x 10 mm fan mount x 1
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 1 (total) / 1 (free) x internal - 2.5"
- Power Device
- Power supply
- Specification Compliance
- FlexATX
- Power Provided
- 200 Watt
- 20 cm
- 30.6 cm
- 7.6 cm
