Akasa 850W Cobra Modular Power Supply (PSU) with Strip Ribbon Cabling
Quicklinx: 8QPKWS00 Mfr#: AK-PA085AM05-UK
850W modular PSU, use the cable you need to reduce clutter. Akasa Cobra PSU features Dynamic single 12V rail for power hungry hardware.
  • Modular cable management enhances airflow.
  • Dynamic single 12V rail for power hungry hardware.
  • Thermally controlled ultra-quiet fan.
  • COBRA strip cable is neat and manageable.
Akasa Cobra 850 - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 30 A , +5V - 28 A , +12V - 63 A , -12V - 0.3 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
135 mm fan
15 cm x 16 cm x 8.6 cm
ATX12V 2.3
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
Efficiency
82%
Cooling System
135 mm fan
Over current protection, over voltage protection, overpower protection, cable management, single 12V rail, temperature controlled fan
15 cm
16 cm
8.6 cm
