Akasa 2 x 12" Dual UV Cold Cathode Lights
Quicklinx: 43FSWS00 Mfr#: AK-188-UV
UV 12" cold cathode dual pack. Lights up your PC interior with bright UV light interact with UV reactive accessories to create unique visual effect. 4mm low power lights inside the clear acrylic tubes for protection. Low heat emissions and long life. Easy, tool free installation with double sided adhesive tapes.
  • 2 UV cold cathode case lights
  • Dual 12V inverter included
  • On/off switch
  • 4mm lo-power tube, only 3 watts
  • Tool free installation
Akasa AK 188-UV - system cabinet lighting (cold cathode fluorescent lamp)
System cabinet lighting (cold cathode fluorescent lamp)
Packaged Quantity
2 (specifications are for single item)
Ultra violet
Length
30.5 cm
Package Type
Retail
Packaged Quantity
Length
30.5 cm
Ultra violet
Package Type
Retail
