An ultra quiet 14 cm case fan delivering high air volumes with low noise acoustic performance of 22.8 dB(A). The cool blue effect is achieved by using four bright blue LED's. Crystal clear frame allows the light to spread providing maximum system illumination to add subtle style to any PC system.
- Akasa Quiet Blue LED AK-FN074 - case fan
- Product Type
- Case fan
- Package Content
- Tool-less fixed pins
- Crystal
- Fan Diameter
- 139 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 56.5 cfm
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Blue LED x4
- 13.9 cm x 13.9 cm x 2.5 cm
- Product Type
- Case fan
- Package Content
- 13.9 cm
- 13.9 cm
- 2.5 cm
- Crystal
Heatsink & Fan
- Fan Diameter
- 139 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1200 rpm
- Air Flow
- 56.5 cfm
- Air Pressure
- 0.84 mm
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Rated Current
- 0.17 A
- Blue LED x4
- Sound Emission
- 22.8 dBA
