Your basket is empty
Akasa 12cm Crystal Green frame & rotor w/ 4 Green LED Fa
Quicklinx: 55VHWS00 Mfr#: AK-274CG-4GNS
Type: Case Fan
£6.15 ex VAT
£7.38 inc VAT
This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
The fan glows a fantastic green, which adds color and style to any PC system.
Akasa Quiet Bright Green AK-274CG-4GNS - case fan
Case fan
Package Content
Screws, 3-pin plug to 4-pin Molex adapter
Crystal green
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
38.4 cfm
Power Connector
3-pin plug, 4 pin Molex connector
Variable fan speed, green LED x4
12 cm x 12 cm x 2.5 cm
Case fan
Package Content
12 cm
12 cm
2.5 cm
Crystal green
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
38.4 cfm
Power Connector
Sound Emission
17.5 dBA
Akasa 12cm Crystal Green frame & rotor w/ 4 Green LED Fa Bundle deal on Akasa 12cm Crystal Green frame & rotor w/ 4 Green LED Fa
£22.16
saving £8.98
Type: Case Fan
Brand: Akasa
Price Range Ex VAT: 0 - 50
