Adaptec RAID 6805E Storage Controller- Serial ATA-600/SAS 2.0
Quicklinx: 7QQPWS00 Mfr#: 2271800-R
Adaptec series 6E unified serial SATA/SAS RAID controller delivers the robustness of hardware RAID and the Adaptec RAID code, enterprise class management features, and full OS support. Delivering the same 6 Gb/s performance of the series 6 controller, the series 6E is optimized for platform where a series 6 controller would not fit in from a price, form factor or host connectivity standpoint.
Series 6E controller supports SATA and SAS devices, and has been qualified with the same systems, motherboards, backplanes and drives as series 6 controller. It includes the same drivers, BIOS and storage management tools as series 6 controller and do not require additional training or qualification. Series 6E controller has also been thoroughly tested with entry-level storage devices for desktop use and the entry-level server platforms, workstations and motherboards most typically used for basic servers, performance workstations or industrial PCs.
  • I/O connectivity and data protection
    With its entry-level price point, Adaptec series 6E can be used as a connectivity product. At the same time, the Adaptec RAID Code (ARC) delivers maximum reliability with RAID levels 0, 1, 1E, 10 and JBOD. ARC also offers RAID level migration, online capacity expansion, and copyback hot spare.
  • The case for cache
    The fastest way for a RAID controller to fulfill a read or write request is to serve data out of its cache. Savvy network administrators know that enabling the RAID controller cache offers significant performance benefits, such as reduced latency in I/O requests, bandwidth and queue depths that surpass software application limits, and on-the-fly parity calculations on sequential writes.
  • Intelligent Power Management
    Intelligent Power Management (IPM) slashes power and cooling costs by up to 70% using intelligent I/O caching combined with disk drive power savings via standby and power-off modes.
Microchip Adaptec RAID 6805E - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe x4
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe x4
Data Transfer Rate
6 Gbit/s
Buffer Size
128 MB
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10, JBOD, RAID 1E
15.5 cm x 6.4 cm
3-year warranty
Host Bus
PCIe x4
Storage Controller
Data Transfer Rate
6 Gbit/s
Buffer Size
128 MB
Supported Devices
Channel Qty
8
RAID Level
PMC-Sierra PM8013
2 x SATA 6Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane (internal)
Compatible Slots
1 x PCI Express x4 - low-profile
Low-profile bracket
2 x Serial ATA / SAS cable - 4 connectors - 70 cm
MTBF
860,953 hours
UL, VCCI, C-Tick, FCC, RoHS, KCC, WEEE, REACH
Software Included
Drivers & Utilities, Adaptec Storage Manager
Limited warranty - 3 years
15.5 cm
6.4 cm
55 °C
