The generation of Adaptec Unified Serial controllers meets your need for maximum performance, scalability, and flexibility for enterprise-class applications, including network attached storage (NAS), online transaction processing (OTLP), web, digital surveillance, and streaming applications.
The Adaptec RAID 5805 is equipped with industry-leading dual core RAID on Chip (ROC), the latest x8 PCI-Express connectivity, and 512 MB of DDR2 cache to deliver over 250,000 IO per second and 1.2 GB/s.
Eight internal ports in this Unified Serial controller allow you to connect up to 256 SATA/SAS disk drives through SAS expanders. The Adaptec RAID 5805 features Adaptec RAID Code (ARC) with RAID levels 0, 1, 1E, 5, 5EE, 6, 10, 50, 60, JBOD, as well as copyback hot spare.
Adaptec Storage Manager provides one-view centralized management of all your Adaptec RAID controllers. The Adaptec RAID 5085 also integrates the latest PCIe connectivity, the broadest operating system support, including open source Linux drivers, a battery backup option, and proven compatibility.
- Microchip Adaptec RAID 5805 - storage controller (RAID) - SATA 3Gb/s / SAS - PCIe x8
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe x8
- Interface
- SATA 3Gb/s / SAS
- Data Transfer Rate
- 3 Gbit/s
- Buffer Size
- 512 MB
- Supported Devices
- Hard drive, disk array (RAID)
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 1E, RAID 5EE, RAID 60
- Package Type
- Retail
- Microsoft Certification
- Works with Windows Vista
- 16.7 cm x 6.4 cm
- 3-year warranty
- Host Bus
- PCIe x8
Storage Controller
- Interface
- SATA 3Gb/s / SAS
- 3 Gbit/s
- Buffer Size
- 512 MB
- Supported Devices
- Channel Qty
- 8
- RAID Level
- Processor
- 1.2 GHz
- 2 x SATA 3Gb/s / SAS - 36 pin 4i Mini MultiLane (internal)
- Compatible Slots
- 1 x PCI Express x8 - low-profile
- Cables Included
- 2 x SAS cable - internal - 1 m
- MTBF
- 873,402 hours
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- UL, VCCI, C-Tick, FCC, RoHS
- Package Type
- Retail
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 16.7 cm
- 6.4 cm
- 0 °C
- 55 °C
