These super-soft silicone fan gaskets are designed to dramatically reduce the vibration from any PC or server case cooling fans. The 80mm, 92mm and 120mm sizes are 2.5mm thick. Included with each gasket are silicone washers and anti-vibration screws. These screws feature a thread design which prevents the shank touching the fan and vibrations being transmitted and amplified through to the chassis.
These gaskets are suitable for the vast majority of case designs and fan combinations, as they fit standard fan mounting holes. Slightly lengthened (12mm thread) fan mounting screws are supplied with the fan gaskets and washers. These gaskets can be used with standard PC cooling fans, and not just with AcoustiFan™ quiet case fans. Note: Do not use these gaskets in very high temperature locations inside a PC/Server such as attached to CPU or GPU heat sinks!
Fitting instructions
1.Fit the fan gasket onto the outside of the fan housing (it will stay on the fan)
2.Position the fan and gasket together against the inside of the case, so that the four mounting holes in the fan and gasket line up to the mounting holes in the case side
3.Locate the four silicone washers and screws, and fit the washers against the case side, each secured by a screw
4.Tighten the screws enough to very slightly compress the silicone rubber. Do not overtighten.
1.Help to absorb the fan vibration
2.Help to 'seal' the small gap between the fan and the casing/enclosure wall
3.Compatible with virtually all case cooling fans
4.Supplied with screws and silicone washers
5.Quick and very easy to fit
