Acer V227bi 27" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: D9ZTWS00 Mfr#: UM.HV7EE.001
Select:
  • 27"
The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
  • Sustainably Designed
    Our Vero monitors are designed to give you a more sustainable choice in displays. This monitor is built with 35% PCR plastics, features 100% recyclable packaging, and is TCO, ENERGY STAR, and EPEAT Silver certified.
  • A Sight to Behold
    Take productivity to the next level with 4K ultra-high definition resolution. Text, images, and more will be crisp and clear for a more enjoyable user experience.
  • Vivid Visuals
    Whether choosing photos or editing videos, the 90% DCI-P3 color coverage with up to 1.07 billion colors and HDR10 support give you more precise colors and enhanced color depth to bring out all the details of your work.
  • Protecting Your Eyes
    This display comes equipped Acer VisionCare eye-protecting technologies such as Acer BlueLightShield, Flickerless, Low-dimming, and ComfyView.
  • Adaptive Sync
    With Adaptive Sync, the monitor's framerate is synced with your graphics card, eliminating screen tearing and delivering ultra-smooth video playback.
  • The Perfect Angle
    Tilt and utilize a VESA mount on this monitor to always have a perfect angle to view your content.
Acer V277bi - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
17 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
61.4 cm x 20.7 cm x 46.4 cm
5.85 kg
United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Display Type
Energy Class
Class F
24 kWh
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
72% NTSC colour gamut
61.4 cm x 20.7 cm x 46.4 cm - with stand
5.85 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA interface support
United Kingdom
Input Voltage
17 W
26.1 kWh/1000h
Power Consumption (Typical)
16.2 Watt
Power Consumption Stand by
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm - weight: 5.85 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
