The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Essential Ergonomics
Planted upon its sturdy and robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. -
Infused with Colour
In the professional world, accuracy is everything. Utilise colour-enhancing and eye care technologies for pinpoint precision -
ZeroFrame Design
The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. -
A Strong, Ergonomic Edge
Courtesy of a firm, stainless steel base, you can easily tilt, pivot, swivel and make height adjustments at a moment's notice. -
Built-in Speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate set up. -
Resolution Matters
Choose from a wide range of resolutions from Full HD up to 4K UHD. -
A Wide Range of Colour
100% sRGB means more colour and more accurate, lifelike images for the professional who demands perfection. -
Designed for Accuracy
Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colours and sharper overall visuals. -
Casually Make Adjustments
No need to fiddle with the buttons. Easily modify your monitor settings via our convenient Acer Display Widget utility software.
- Acer B277U - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 32.1 W
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 75 Hz
- Brightness
- 350 cd/m²
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.4 cm x 6.82 cm x 52.8 cm
- Environmental Standards
- TCO Certified Displays 8
- Display Type
- Energy Class
- Class G
- 52 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- ErgoStand, frameless, Acer Adaptive Contrast Management (ACM), 6-axis colour adjustment, Adaptive-Sync technology, Acer VisionCare
- Black
- 61.4 cm x 6.82 cm x 52.8 cm - with stand
Audio
- Speakers - stereo
- DisplayPort , HDMI
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Height Adjustment
- 120 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 6.82 cm - height: 52.8 cm , Without stand - width: 61.4 cm - depth: 6.82 cm - height: 36.7 cm
- TCO Certified
