Acer V176LBMD 17'' 1280x1024 5ms VGA DVI-D LED Monitor
Quicklinx: 9144WS00 Mfr#: UM.BV6EE.005
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. This sturdy monitor also has a wide array of ports, so you can connect many types of devices and do more at once. In addition, it utilizes eco-friendly features to save power and money.
Acer V176Lbmd - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
39.45 cm x 19.1 cm x 36.9 cm
United Kingdom, Europe
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
17"
Panel Type
TN
Native Resolution
Pixel Pitch
0.264 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
HDCP, 72% NTSC colour gamut
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
MTBF
30,000 hours
GS, ISO 9241-307
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Included Software
Drivers & Utilities, Acer eDisplay Management
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
