Acer RC271U 27" 2560x1440 4ms DVI HDMI DP LED Monitor
Quicklinx: DB07WS00 Mfr#: UM.HR1EE.009
Wash away thick borders and enter a world of ZeroFrame design. A world that is seamless, ultrathin and styled in finesse. Rich, vivid colors spring forth in 2560x1440 resolution on the IPS display of the RC1 monitor.
  • Seriously thin
    At a mere 7 mm thickness, you might miss the RC1 monitor at first glance but will have a hard time looking away.
  • ZeroFrame design
    The ZeroFrame design makes for a near-seamless look, allowing you to see more of what matters most: the screen.
  • Stand tall & clear
    A diamond-cut C-shaped metal stand with a firm transparent neck holds the RC1 aloft, allowing a tilt of -5° to 15°.
  • Built-in speakers
    A pair of built-in 2W speakers make sitting back and relaxing with your favorite media that much easier.
  • A wide world
    The RC1 is a 16:9 (2560x1440) WQHD monitor. The screen is wide, the images are sharp and the view is perfect.
  • IPS Panel
    The RC1 monitor features an IPS panel, allowing colors to be presented accurately with a viewing angle of up to 178°.
  • Spectacular 100% sRGB color
    With 100% sRGB coverage, colors are consistent without deviation in color reproduction.
  • Acer VisionCare
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer RC271U - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 100/240 V (50/60 Hz)
Black, silver
61.5 cm x 20.1 cm x 44.5 cm
3.81 kg
France
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class A
39 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Zero Frame
Black, silver
61.5 cm x 20.1 cm x 44.5 cm - with stand
3.81 kg
DVI , HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA interface support
1 x DVI cable , 1 x DisplayPort cable
MPR II
France
Input Voltage
27 W
Power Consumption (Typical)
27 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.1 cm - height: 44.5 cm - weight: 3.81 kg , Without stand - width: 61.4 cm - depth: 3.7 cm - height: 36.4 cm - weight: 3.4 kg
Sustainability Information
ENERGY STAR Certified
