Acer P7505 1920x1080 5000 Lumens WUXGA 3D LED Projector
Quicklinx: BK65WS00 Mfr#: MR.JH211.002
The professional Acer P7 series employs advanced technologies and convenient setup utilities to deliver clear, persuasive presentations in large business venues. Enterprising innovators like you will appreciate the high resolution, brightness and contrast ratio to drive your ventures toward greater success.
  • Remarkable visuals
    This professional projector is the perfect workhorse for big meetings, presenting fantastically clear and vibrant images even in amply lit venues. Acer's advanced color technologies ensure color brilliance, and guarantee consistent image quality despite prolonged use.
  • Wireless convenience
    Experience true presentation freedom - project from any PC in the room over 802.11 b/g/n network, or use the MobiShow application to present from a Windows Mobile smartphone. You can also use the remote desktop feature to access content from any PC that's connected to the projector via LAN and has launched the Acer eProjection utility. What's more, the P7 series complies with the Crestron network system so you can control the projector over LAN.
  • Installation flexibility
    The Acer side-loading lamp design makes lamp replacement trouble-free, even while the projector remains ceiling-mounted. The keystone correction feature eliminates distortions resulting from elevated or side projection. Furthermore, with the display over USB feature, images from your PC can be displayed as soon as a USB cable connects the PC and projector.
Acer P7505 - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Europe, EMEA
Microdisplay
DarkChip 3
Brightness
5000 ANSI lumens
Contrast Ratio
10000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
P-VIP 370 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
460 Watt
39.8 cm x 31 cm x 13 cm
7 kg
3-year warranty
3D Capable
Europe, EMEA
Projector
Microdisplay
DarkChip 3
Brightness
5000 ANSI lumens
Brightness (Reduced)
4000 ANSI lumens
Contrast Ratio
10000:1
Image Size
50.8 cm - 762 cm
Projection Distance
1 m - 10 m
Throw Ratio
1.5 - 2.28:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
144 Hz x 100 kHz
Bulb type
P-VIP 370 Watt
Bulb life cycle
6-segment colour wheel, BrilliantColor, USB host function, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, SpectraBoost, Quick-Start
Lens
Focus Type
Manual
Lens Aperture
F/2.45-2.9
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Lens Shift Type
Manual
Vertical Lens Shift
12.5% / 12.5%
Horizontal Lens Shift
15% / 15%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x remote control - mini-phone 3.5 mm
Carrying case, lens cover, dust cover, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
Security lock slot (cable lock sold separately), PIN code
TUV GS, FCC, ROSTEST
AC 120/230 V
460 Watt
Power Consumption Stand by
0.5 Watt
39.8 cm
31 cm
13 cm
7 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
36 dBA
30 dBA
