Acer P1285 XGA 3300 Lumens DLP Projector
Quicklinx: DHDYWS00 Mfr#: MR.JLD11.00L
Acer P1285 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
3200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
254 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.3 kg
DLP projector
3D Capable
Projector
Brightness
3200 ANSI lumens
Brightness (Reduced)
2560 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
61 cm - 762 cm
Projection Distance
1 m - 11.3 m
Throw Ratio
1.86 - 2.04:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology, ColorBoost 3D Technology, ExtremECO
Lens
Focus Type
Manual
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x USB - 4 pin USB Type A
Carrying case, wireless remote control
1 x VGA cable
Power Source
AC
254 Watt
30.8 cm
21.1 cm
8.6 cm
2.3 kg
Sound Emission
30 dBA
26 dBA
