Prolonged screen viewing can cause your eyes to become sore and fatigued. Luckily, Acer KA1 series monitors help to lessen these nasty side effects with technologies that reduce screen flicker, ambient glare and irritating blue light.
Adapts to your environment
Low dimming technology adjusts screen brightness based on ambient light. When your surroundings are brightly lit, they'll turn brightness up. Conversely when it's dark, they can adjust down. -
Place it right
The position of the screen is also important in ensuring a comfortable viewing experience. Therefore, KA1 series monitors are equipped with adjustable ergonomic screens that can be titled.
- Acer KA241Y - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class F
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 21.8 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 54 cm x 21.3 cm x 42.2 cm
- 4.11 kg
- MPR II
- Display Type
- Energy Class
- Class F
- 38 kWh
- Diagonal Size
- 23.8"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Low Dimming technology
- Black
- 54 cm x 21.3 cm x 42.2 cm - without stand
- 4.11 kg
- DVI , HDMI , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x VGA cable
- MPR II
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 21.8 W
- Power Consumption SDR (On mode)
- 21.8 kWh/1000h
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 0.35 Watt
- 0.35 Watt
- Dimensions & Weight Details
- Without stand - width: 54 cm - depth: 21.3 cm - height: 42.2 cm - weight: 4.11 kg
