Acer KA220HQ 21.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: BQRMWS00 Mfr#: UM.WX0EE.B01
Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Full-featured for everyone
    Eco-friendly Acer KA2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connexion ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
  • Stunning performance
    You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colours via Acer Adaptive Contrast Management.
  • Comfortable views
    The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colours for you viewing enjoyment.
  • Smart design
    Set the KA2 Series' display angle to optimise your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Environment-friendly
    Safe for you and your world, KA2 Series monitors feature mercury-free white LED backlighting and meet ENERGY STAR 6.0 requirements. Acer EcoDisplay technologies use arsenic-free display glass, further protecting the environment. Acer packaging is also made of recyclable materials.
Acer KA220HQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
50.8 cm x 16.4 cm x 40.24 cm
Microsoft Certification
Compatible with Windows 7
3-year warranty
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 16.4 cm x 40.24 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
18.1 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 16.4 cm - height: 40.24 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
Limited warranty - 3 years
BQRM C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
