Acer K222HQLC 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: CXFKWS00 Mfr#: UM.WX2EE.C01
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
50.8 cm x 20.7 cm x 39.05 cm
3.1 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
29 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, 6-bit gamma
50.8 cm x 20.7 cm x 39.05 cm - with stand
3.1 kg
Audio
Speakers
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MPR II
Input Voltage
19 W
19 kWh/1000h
Power Consumption (Typical)
18.1 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.05 cm - weight: 3.1 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 2.7 kg
Sustainability Information
ENERGY STAR Certified
