Acer G277HLbid 27'' 1920x1080 VGA DVI HDMI Gaming Monitor
Quicklinx: CPCYWS00 Mfr#: UM.HG7EE.011
Acer G7 Series monitors give you the outstanding visuals you want and the value you need. With a Zero Frame design and multiple color options, these stylish monitors fit perfectly in your home or office. Visuals are sharp and vivid on G7 Series monitors, thanks to Full HD resolution and IPS technology.
The futuristic style of the G7 Series incorporates a slim Zero Frame design that saves space on your desk and lets you place multiple G7 monitors side by side to build a seamless big-screen display. You can pick the color that fits your style and you can tilt the display from -5 to 15 degrees, for comfortable viewing.
Images on the G7 Series come to life thanks to IPS technology with deeper black levels, crisper whites and stronger colors, even when viewed from wide angles.
Acer CrystalBrite technology on the G7 Series offers greater color intensity. You'll enjoy tasks and entertainment more, thanks to the finer details delivered by Full HD resolution.
  • Beauty from all angles
  • Slim and elegant
  • Expansive views
  • Vivid color
  • Green perspective
    The G7 Series monitors are RoHS compliant and mercury free. Plus, advanced Acer EcoDisplay technologies and white LED backlighting save power to cut your costs and conserve the planet's resources. Acer also uses recyclable packaging, further reducing ecological impact.
Acer G277HL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
39 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
70% NTSC
Input Connectors
HDMI, DVI, VGA
Screen Coating
Anti-glare
Voltage
62.2 cm x 20.3 cm x 45.5 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class A
39 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
70% NTSC
Response Time
6 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Tilt
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), Zero Frame, Mercury free
62.2 cm x 20.3 cm x 45.5 cm - with stand
VGA , DVI (HDCP) , HDMI
Mechanical
Tilt Angle
-5/+15
Stand
1 x VGA cable
MTBF
30,000 hour(s)
MPR II
Power Supply
External
Input Voltage
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
400 mW
Dimensions & Weight Details
With stand - width: 62.2 cm - depth: 20.3 cm - height: 45.5 cm , Without stand - width: 62.2 cm - depth: 3.4 cm - height: 36.8 cm
Sustainability Information
ENERGY STAR Certified
