Acer G226HQLH 21.5" 1920x1080 8ms DVI HDMI LED Monitor
Quicklinx: 9LB0WS00 Mfr#: UM.WG6EE.H05
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced 1080p Full HD gaming, multimedia and productivity applications, providing advantages.
Acer monitors using white LED backlight technology minimize environmental impact while offering superior performance and durability. White LED monitors do not contain the toxic substance mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, resulting in big savings.
  • Full HD LED monitor
  • Acer eColor management
    A single button - the empowering key - grants full access to the Acer eColor Management onscreen interface. Acer eColor Management provides a variety of advanced controls for achieving the best-possible image quality.
  • Dependable functionality
    This monitor complies with the Windows 7 operating systems; has undergone rigorous durability testing; and adheres to high safety standards to ensure reliability and comfortable viewing.
  • Acer EcoDisplay
Acer G226HQLHbid - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
51.1 cm x 3.6 cm x 31.1 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP
51.1 cm x 3.6 cm x 31.1 cm - without stand
2.6 kg
VGA , DVI (HDCP) , HDMI
Mechanical
Tilt
Tilt Angle
20
1 x VGA cable
MPR II
Input Voltage
AC 120/230 V
Power Consumption (Typical)
20.5 Watt
Power Consumption Stand by
340 mW
Power Consumption Sleep
300 mW
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 16.8 cm - height: 36.5 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
9LB0 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
