Acer ET430Kwmiippx 43" 3840x2160 5ms HDMI DP  Monitor
Quicklinx: CP8VWS00 Mfr#: UM.ME0EE.008
Acer ET430Kwmiippx - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class A
Energy Consumption per Year
100 kWh
Power Consumption (On mode)
55 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
96.59 cm x 24.28 cm x 65.33 cm
MPR II, TUV GS, ISO9241-307
Display Type
Energy Class
Class A
100 kWh
Diagonal Size
43"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
96.59 cm x 24.28 cm x 65.33 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+11.5
VESA Mounting Interface
200 x 100 mm
MTBF
30,000 hour(s)
Input Voltage
AC 120/230 V
55 W
Power Consumption (Typical)
55 Watt
Power Consumption Sleep
0.45 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 96.59 cm - depth: 6.53 cm - height: 56.15 cm , With stand - width: 96.59 cm - depth: 24.28 cm - height: 65.33 cm
