Acer ED323QU 31.5" 1920x1080 4ms DVI HDMI DP Curved LED Monitor
Quicklinx: DPQCWS00 Mfr#: UM.JE3EE.A01
  • Vibrant images
    Crisp, true-to-life colours come alive in Full HD 1080p resolution.
  • Curved screen
    Sharp 1800R curved screens provide more impressive experiences.
  • Wide angle display
    Share what's on your screen with friends and family as colours stay true no matter what angle you're viewing from.
  • Stay in the game
    The ED3 ensures you can enjoy all your favourite games with AMD FreeSync compatibility.
  • Silky smooth visuals
    With a rapid refresh rate, the Acer ED3 delivers ultra-smooth viewing with faster frame rendering and lower input lag.
  • High-speed response
    Keep pace with the action as the rapid response time reduces ghosting and smearing for clearer, more precise images.
  • Care for your vision
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer ED323QUR - LED monitor - curved - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class G
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
37.2 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 (DisplayPort: 144 Hz, DVI: 75 Hz, HDMI: 144 Hz)
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
85% NTSC
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
71.3 cm x 16.9 cm x 51 cm
6.1 kg
Belgium, Netherlands, Sweden
Environmental Standards
ENERGY STAR Qualified
MPR II, FCC, RoHS
Display Type
Energy Class
Class G
48 kWh
Diagonal Size
31.5"
Curved Screen
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
85% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, 8-bit gamma, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
71.3 cm x 16.9 cm x 51 cm - with stand
6.1 kg
DisplayPort , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x DisplayPort cable
MPR II, FCC, RoHS
Input Voltage
37.2 W
37.2 kWh/1000h
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
500 mW
Power Consumption (Off Mode)
500 mW
Dimensions & Weight Details
With stand - width: 71.3 cm - depth: 16.9 cm - height: 51 cm - weight: 6.1 kg , Without stand - width: 71.1 cm - depth: 7.9 cm - height: 41.5 cm - weight: 5.27 kg
Sustainability Information
ENERGY STAR Certified
