CB1 Series monitors are designed for a great visual experience. With vivid high-resolution, clarity and comfort, they produce sharp images and true-to-life color. The also come packed with features to enhance the visual experience while providing added comfort and protection.
Visually outstanding
CB1 series monitors combine multiple features and technologies to produce a superior visual experience. With excellent resolution, wide viewing angles and added color and clarity enhancement technologies, it's a beautiful view. -
ColorPlus
With the CB1 series, you not only get great overall specs. The ColorPlus enhancements, including 100% sRGB, 6-axis color adjustment and Super Sharpness features, seriously up your display game with advanced color capability, adjustment and image clarity. -
Double up
When one screen just isn't enough, the CB1 has additional options that let you see double. With both Picture-in-Picture and Picture-by-Picture options, you can connect a second computer and see both displays simultaneously. -
Protective comfort
CB1 displays are a bonanza of features that both improve your viewing experience and help reduce eye strain. The flicker-less display has blue light filter and glare reduction features that significantly improve viewing comfort while enhancing eye protection. -
Take it to the edge
With CB1 displays you have the added option of the zero-frame design which virtually removes the display bounding box and gives you all image, edge to edge. -
Usability enhancements
All CB1 monitors have enhanced ergonomics thanks to the clever design of their supporting ErgoStand, which enables a wide range of tilt, swivel and height adjustments. With the ErgoStand, you can adjust the display to practically any position and purpose. -
No screen tearing
Say "goodbye" to stuttering and tearing. FreeSync and Adaptive-Sync technologies match the refresh rate of your monitor with your graphics card to provide smooth gaming experience.
- Acer CB271HB - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 60 kWh
- Power Consumption (On mode)
- 41 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64 cm x 23.6 cm x 55.1 cm
- 7.35 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 60 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 64 cm x 23.6 cm x 55.1 cm - with stand
- 7.35 kg
Audio
- Speakers
- VGA , DVI , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- 41 W
- Power Consumption (Typical)
- 25.8 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.4 kg , With stand - width: 64 cm - depth: 23.6 cm - height: 55.1 cm - weight: 7.35 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
