Acer CB271H 27" 1920x1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: CXF8WS00 Mfr#: UM.HB1EE.001
CB1 Series monitors are designed for a great visual experience. With vivid high-resolution, clarity and comfort, they produce sharp images and true-to-life colour. The also come packed with features to enhance the visual experience while providing added comfort and protection.
  • Visually outstanding
    CB1 series monitors combine multiple features and technologies to produce a superior visual experience. With high resolutions, wide viewing angles and added color and clarity enhancement technologies, it's a beautiful view.
  • Protective comfort
    CB1 displays are a bonanza of features that both improve your viewing experience and help reduce eye strain. The flicker-less display has blue light filter and glare reduction features that significantly improve viewing comfort while enhancing eye protection.
  • Usability enhancements
    All CB1 monitors have enhanced ergonomics thanks to the clever design of their supporting ErgoStand, which enables a wide range of tilt, swivel and height adjustments. With the ErgoStand, you can adjust the display to practically any position and purpose.
Acer CB271H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
64 cm x 23.7 cm x 55.2 cm
7.33 kg
Environmental Standards
ENERGY STAR Qualified
FCC Part 15, WEEE, Directive 1275/2008, Directive 2009/125/EC, EN 50564:2011, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, IEC 62301:2011, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
3-year warranty
Display Type
Energy Class
Class B
60 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
1 ms
Backlight Technology
LED backlight
ErgoStand, picture by picture, frameless, Zero Frame, 6-axis colour adjustment
64 cm x 23.7 cm x 55.2 cm - with stand
7.33 kg
Audio
Speakers
VGA , DVI , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
Acer Eyeprotect technology
1 x VGA cable , 1 x DVI cable
41 W
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.4 kg , With stand - width: 64 cm - depth: 23.7 cm - height: 55.2 cm - weight: 7.33 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
