Acer provides a full scale of hardware and software products to meet the demands of today's business environment. Among the wide portfolio of Acer's business products, the B6 series are an extensive monitors range designed to cover any professional need. The stylish and simple ergonomic design enhances comfort over prolonged periods and increases productivity. Advanced panel technologies make every pixel colorful and vibrant, while compliance with eco-friendly standards helps save power and cut costs, reducing environmental impact.
Ergonomic design
Combining professional style with ergonomic design and reflection-free Acer non-glare displays, the Acer B6 monitors perfectly suit all environments and viewing demands. Designed for professionals that spend a lot of time in front of a computer, Acer monitors can be adjusted to enhance the comfort over prolonged use. Moreover, Acer ComfyView feature reduces the reflection of ambient light to deliver vivid colors and less glare for the best viewing experience. The polarizer material diminishes unnecessary lighting reflection. -
Outstanding color performance
Acer ColorPlus is a set of technologies that ensures real and consistent color output in addition to sharper and clearer visuals. Built-in 100% sRGB color correction technology delivers the high color accuracy and color space reproduction desired by design professionals and photo enthusiasts for accurate color matching across applications and print output. A low Delta E value ensures accurate and consistent color, which substantially improves display quality, producing true color quality and uniform appearance across monitors. In addition, a 6-axis color independent adjustment permits precise color and saturation control for customized settings. The 178-degree wide viewing angle technology preserves image clarity and display colors without color shift or image distortion. In addition, extreme Black Monitor helps to deliver image details with deeper black levels, while the super sharpness technology optimizes lower resolution images for clearer image quality on a higher resolution monitor, for example, optimizing a 1080p photo for a 4K display. -
Acer Adaptive Contrast Management
The B6 series feature Acer Adaptive Contrast Management, a technology that fine-tunes each scene to make bright areas brighter and dark areas darker, optimizing contrast, for more detailed moving images. Acer Adaptive Contrast Management improves the input image directly, thereby realizing the full capability of the panel. Images look ultra-sharp and power is used efficiently. -
White LED technology
Acer B6 series integrate White LED technology that eliminates hazardous substances such as mercury or halogen gases and allows the reduction of power consumption by up to 68% compared to the traditional CCFL displays. What's more, LED lamps not only ensure exceptional reliability and great savings but also deliver better performance. In fact, they allow the reproduction of a larger color range with better saturation. The result is remarkable realism, unobtainable with standard technologies. -
Acer Ergo-Stand
Acer B6 monitor series comes with Acer Ergo-Stand, ensuring superior ergonomics and comfortable use. Featuring flexible height, tilt, pivot adjustment and a swivel foot-stand, B6 monitors easily adapt to any work style and blend into any office environment. -
Height adjustment
With height adjustment, users having different desks and heights can find the most suitable position for comfortable viewing. The stainless constant force spring stops at any height simply by pushing or lifting. You can adjust the height of B6 series up to 150mm. -
Pivot
The pivot design of the B6 series permits to rotate the display in portrait mode, which is useful for specific purposes such as scrolling through long web pages. -
Tilt
The tilt design ensures the best viewing angle for daily operation. You can adjust the viewing angle of B6 monitors from -5° to 35°. -
Swivel
With a swivel angle of 120°, B6 series monitors can be easily rotated on the stand, so that users can share the screen and let colleagues watch comfortably. -
Maximum color accuracy
Specifically designed for demanding users, Acer B6 High resolution monitors feature Acer ColorPlus, a set of technologies that ensures real and consistent color output in addition to sharper and clearer visuals. Built-in 100% sRGB color correction technology delivers the high color accuracy and color space reproduction desired by design professionals and photo enthusiasts for accurate color matching across applications and print output. A low Delta E value ensures accurate and consistent color, which substantially improves display quality, producing true color quality and uniform appearance across monitors. In addition, a 6-axis color independent adjustment permits precise color and saturation control for customized settings. The 178-degree wide viewing angle technology preserves image clarity and display colors without color shift or image distortion. In addition, extreme Black Monitor helps to deliver image details with deeper black levels, while the super sharpness technology optimizes lower resolution images for clearer image quality on a higher resolution monitor, for example, optimizing a 1080p photo for a 4K display. -
Superior usability
With Super Sharpness technology every detail comes into focus, making edges sharper and optimizing image quality. These monitors are also equipped with Low Dimming technology, that reduces the display brightness in dark environments to prevent eyestrain. In addition, large panels (up to 32"), resolutions up to 4K2K (four times Full HD) and cinematic 21:9 aspect ratio (B296CL model) make these monitors flexible to adapt to different usage scenarios. -
Extensive connectivity
Acer B6 High resolution monitors come with a rich stock of ports, including DVI, DisplayPort, MHL and USB 3.0 to seamlessly connect many types of devices. These monitors can be used to set up multiple displays configurations with daisy chain through video ports. The Picture in Picture feature allows better collaboration and productivity by joining two systems to a B6 monitor to share the same ultra-resolution working area.
- Acer B246WL - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class G
- Power Consumption (On mode)
- 28.3 W
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), tilt
- Voltage
- AC 120/230 V
- Dark grey
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- ErgoStand, HDCP, Acer Adaptive Contrast Management (ACM), Zero Frame
- Dark grey
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI , DisplayPort , Audio line-out
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
- Input Voltage
- AC 120/230 V
- 28.3 W
- Power Consumption SDR (On mode)
- 28.3 kWh/1000h
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Sleep
- 0.45 Watt
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
