Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. The microlouver technology in our world-class privacy filter helps protect the confidential and sensitive information displayed on your monitor from the side-views of visual hackers. The matte surface helps reduce glare and hide fingerprints, so you get crisp image clarity on your screen, while visual hackers with side views are kept in the dark.
- 3M Privacy Filter for 24" Widescreen Monitor (16:10) - display privacy filter - 24" wide
- Product Type
- Display privacy filter
- Black
- Display Screen Size Compatibility
- 24" wide
- Product Material
- Plastic
- 51.9 cm 32.5 cm
- 1-year warranty
- Product Type
- 24" wide
- Product Material
- Plastic
- 51.9 cm 32.5 cm
- Black
Display Filter
- Viewing Area Height
- 32.5 cm
- Viewing Area Width
- 51.9 cm
- Aspect Ratio
- 16:10
- Surface Finish
- Matte
- Scratch Resistant
- Frameless
- Limited warranty - 1 year
