3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 17 5/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 15 1/16" wide x 8 1/2" high (383 mm x 215 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M LCD Privacy Computer Filter display privacy filter - 17.3"
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 17.3"
- 38.3 cm 21.5 cm
- 1-year warranty
- Designed For
- Alienware M17x; Dell Inspiron 17 5748, 17 5749, 17 7746, 17R, 17R 5720, 17R 5721, 17R 5737, 3721, 3737, 5758, 7737; Precision M6600, M6700
- Product Type
- 17.3"
- 38.3 cm 21.5 cm
- Limited warranty - 1 year
- Designed For
- Alienware M17x , Dell Inspiron 17 5748, 17 5749, 17 7746, 17R, 17R 5720, 17R 5721, 17R 5737, 3721, 3737, 5758, 7737 , Dell Precision M6600, M6700
