3Com offers a large selection of antennas specifically designed to optimize 802.11 connectivity in a range of environments. These antennas increase the coverage area of 3Com wireless LAN (WLAN) bridges and enterprise access points with removable antennas. Antenna cables offer length options.
The 3Com Ultra Low Loss 6-Foot Antenna Cable (SMA to N connectors) connects an external antenna to selected 3Com wireless LAN (WLAN) enterprise access points with removable antennas. Ultra low loss characteristics ensure the maximum performance of your external antenna installation. Supported 3Com Access Points include: 2750, 3150, 3750, 3850, 7760, 8760, 9150, 9550, 9552.
- 3Com Ultra Low Loss - antenna cable - 1.8 m
- Antenna cable
- Technology
- Coaxial
- Length
- 1.8 m
- Connector
- N-Series connector - male
- Connector (Second End)
- SMA - male
- 1-year warranty
- Designed For
- P/N: 3CWE591, 3CWE592, 3CWE596, 3CWE597, 3CWE598
- Network Cable Type
- Antenna cable
- Technology
- Coaxial
- Length
- 1.8 m
- Connector
- SMA - male
- 1-year warranty
- Designed For
