2-Power Laptop Universal Charger - with a 2.1A USB
Quicklinx: 9KF5WS00 Mfr#: CUA5092A-UK
Slimline 90W Universal Laptop Adapter
The 2-Power Slimline 90W Universal Laptop adapter comes supplied with 8 tips that cover over 95% of all Laptops & Notebooks on the market. It is an extremely slim adapter with snap on tips that automatically sense and select the correct voltage for your laptop. This means it is incredibly safe and easy to use without the worry of damaging your laptop.
You can also charge USB chargeable devices such as Tablet PC's or Smartphones via a single usb socket.
2-Power Universal Slimline - power adapter - 90 Watt
Power adapter - external
United Kingdom
Input Voltage
AC 230 V
Power Capacity
90 Watt
8 notebook power tips
12.2 cm x 6.8 cm x 2.1 cm
1-year warranty
United Kingdom
Input Voltage
AC 230 V
Power Capacity
90 Watt
Limited warranty - 1 year
12.2 cm
6.8 cm
2.1 cm
