2-Power AC Adapter 12V 45W Includes Power Cable
Quicklinx: BM8BWS00 Mfr#: CAA0741G
Marketing description is not available.
  • Efficient power supply
    The power adapter is designed to provide a consistent and reliable power output, ensuring that devices operate smoothly without interruptions.
  • Broad compatibility
    With a voltage requirement of AC 110-240 V, this adapter can be used in various regions, making it suitable for both home and travel use.
  • Compact external design
    The external form factor allows for easy connection and disconnection, making it convenient to use with different devices.
2-Power - power adapter - 45 Watt
Power adapter - external
128 g
Input Voltage
AC 110-240 V
Output Voltage
12 V
Power Capacity
45 Watt
8.5 cm x 3.4 cm x 2.6 cm
1-year warranty
Microsoft Surface 2, RT
Input Voltage
AC 110-240 V
Output Voltage
12 V
Max Electric Current
3.6 A
Power Capacity
45 Watt
Limited warranty - 1 year
8.5 cm
3.4 cm
2.6 cm
128 g
