Zyxel XGS1910-48 48 port Gigabit Smart Managed Switch w 10G uplink
FREE 3 YEAR NBD REPLACEMENT WARRANTY
Quicklinx: 8NV0WS00 Mfr#: XGS1910-48-GB0101F
The XGS1910 series is ideal for securing 10/100, Gigabit and 10 GbE connectivity; it also offers IEEE 802.3az, access security, advanced prioritization, traffic-monitoring capabilities and a fanless design. Meanwhile, the series supports smooth IPv6 migration for future expansions. As a result, the XGS1910 series is suitable for fulfilling SMB network needs with cost-effective, valuable frameworks.
  • Smart Layer 2 features enrich access networks
    The ZyXEL XGS1910 series is providing comprehensive Layer 2 switching capabilities such as Access Control List (ACL) rules, 802.1p Priority Queues per Port and 802.1AB LLDP and LLDP-MED, etc. The series delivers the essential network features for businesses with easy-to-use management at a right price. That is, the XGS1910 series is the best edge switch range for small- and medium-size businesses to build high-performance network efficiently.
  • GbE bandwidth for desktops
    When videos of higher resolution and data flow constantly evolve, network user demands might not be satisfied and business operations hampered by insufficient bandwidth. The ZyXEL XGS1910 series provides GbE bandwidth to desktops to ensure sufficient bandwidth for all business communications, data delivery and daily operations. Taking advantages of GbE, businesses can create premium worry-free IT environment and expand operations with desirable efficiency and productivity.
  • Energy management with IEEE 802.3az
    As operating overheads such as electric bills increase constantly due to the rising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) features of ZyXEL XGS1910 series can reduce energy consumption of Ethernet devices through defining low-power modes and adjusting the operating timeframe to help saving the related costs effectively.
Zyxel XGS1910-48 - switch - 48 ports - Managed
Switch - 48 ports - Managed - stackable
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+
Performance
Non-blocking switching capacity: 176 Gbps , Forwarding performance: 131 Mpps
MAC Address Table Size
32K entries
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, HTTP
Flow control, auto-negotiation, ARP support, trunking, VLAN support, packet filtering, store and forward, MAC address filtering, IPv6 support, IP address filtering, half duplex mode, full duplex mode, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, bandwidth control, LACP support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, loop prevention, port isolation, congestion control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, UPnP
43 cm x 25 cm x 4.4 cm
3.1 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Max Units In A Stack
8
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
RAM
4 MB
Status Indicators
Power, system, alarm, link/activity
48 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 4 x SFP (mini-GBIC) , 1 x console DB-9 , 4 x SFP+
Internal power supply
61 Watt
FCC, RoHS, BSMI CNS 13438, ICES, BSMI CNS 14336, LVD
United Kingdom
43 cm
25 cm
4.4 cm
3.1 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
