The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device.
Standard-based design assures compatibility
The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies. -
Hot-swappable design facilitates network maintenance
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device. -
Bi-directional transceivers maximizes usage of existing fiber plant
Traditional fiber optic networking requires two strands of fiber to accomplish communications, in which one strand is reserved for sending signals, while the other is for receiving. On the other hand, bi-directional, dual-wavelength transceivers can establish communications over just one strand of fiber by using two separate optical wavelengths: one receives and the other transmits signals. Transmission capacity can be expanded immediately without additional cost laying new fiber. -
Supporting DDMI (Digital Diagnostics Monitoring Interface) SFP enhances management capability
The enhanced digital interface enables a real time link to be established between the switch and the SFP transceiver. This enables the switch to access operating parameters within the fiber link. This includes digital features such as soft control and monitoring of SFP I/O signals. In addition the DDMI functionality enables the capability to implement digital alarms and warnings. This feature ensures that the business can be proactive in preventative maintenance of the network and ensure business continuity.
- Zyxel XFP-ER - XFP transceiver module - 10GbE
- XFP transceiver module - SC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-ER
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1550 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 40 km
- 5-year warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-ER
- 10GbE
- 10 Gbps
- 1550 nm
- 40 km
- 1 x Ethernet 10GBase-ER - SC single-mode
- Compatible Slots
- 1 x XFP
- Limited warranty - 5 years
