Zyxel WRE6505 - 802.11a/b/g/n/ac - Dual Band Network Extender
Quicklinx: 9TG4WS00 Mfr#: WRE6505-GB0101F
Easily Expanding Home Wireless Coverage with Dual-Band Technology
ZyXEL's WRE6505 Wireless AC750 Range Extender provides wireless coverage throughout your home. Just plug the unit into a power outlet, and LED lights will indicate signal strength so you can place it on the optimum spot. The one-click Wi-Fi Protected Setup (WPS) setup simplified installation while a built-in Ethernet port provides instant network connection to multiple wired devices.
Easy Wireless Extension - Expand wireless coverage easily
The ZyXEL WRE6505 extends and broadens your 802.11 a/b/g/n/ac wireless network coverage by eliminating dead spots for whole-home coverage. It allows you to enjoy the fastest video streaming, gaming and Web browsing on tablets, laptops or smartphones anywhere in the house, and it's backward compatible with all your current 802.11 a/b/g/n routers and access points.
Extender/AP Switch Mode
Dual-band technology with "Speed/Range Boost" for advanced performance
The "Speed Boost" and "Range Boost" modes of the ZyXEL WRE6505 help establishing interference-free, optimal throughput as well as coverage. Choose the "Range Boost" mode for maximum wireless coverage or "Speed Boost" mode to prioritize speed over coverage.
Dual-Band
Compliant with 802.11ac with dual-band concurrent wireless
The ZyXEL WRE6505 is backward compatible with all your current 802.11 a/b/g/n routers and access points; and it helps to transmit signals using the less-crowded 5 GHz band for smooth streaming and low latency for games.
Compact wall-mount design for convenient deployment
The ZyXEL WRE6505 has been designed to allow flexible deployment, giving you the best wireless coverage and performance while eliminating the unsightly wires. Additionally, the device offers LED of three colors (red-good/amber-better/green-best) to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy your high-speed wireless network throughout your home in minutes.
  • Expand wireless coverage easily
  • Dual-band technology with "Speed/Range Boost" for advanced performance
  • Compliant with 802.11ac with dual-band concurrent wireless
  • Compact wall-mount design for convenient deployment
    The ZyXEL WRE6505 has been designed to allow flexible deployment, giving you the best wireless coverage and performance while eliminating the unsightly wires. Additionally, the device offers LED to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy your high-speed wireless network throughout your home in minutes.
Zyxel WRE6505 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
4.65 cm x 6.23 cm x 9.09 cm
98 g
4.65 cm
6.23 cm
9.09 cm
98 g
United Kingdom
External
Wireless
Data Transfer Rate
450 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, WLAN, LAN, WPS
Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
1 x 100Base-TX - RJ-45
1 x network cable
FCC, LVD
Internal power supply
3 Watt
10 - 90% (non-condensing)
