Zyxel WRE2205V2-GB0101F Wireless N300 Range Extender
Quicklinx: 9Q97WS00 Mfr#: WRE2205V2-GB0101F
Plug-and-Play Extension for Better Wireless Coverage
Designed as a user-friendly alternative to complicated, unsightly network extension options, the ZyXEL WRE2205 v2 Wireless N300 Range Extender makes expanding the range of your 802.11 b/g/n wireless network fast and easy. Just plug the unit into a power outlet and the LED light will indicate signal strength, so you can place it in the most suitable spot. The one-click Wi-Fi Protected Setup (WPS) setup makes installation even more frustration-free while the built-in Ethernet port provides instant network access to wired devices.
Expand wireless coverage easily
Compatible with 802.11 b/g/n wireless networks, the ZyXEL WRE2205 v2 helps extending and broadening the wireless network coverage of your home. It allows you to enjoy video streaming, gaming and Web browsing with tablets, laptops or smart phones anywhere at home without dead spots.
Compact wall-mount design for convenient deployments
The device has been designed to allow flexible deployments, giving you the best wireless coverage and performance as well as eliminating the need for unsightly wires. Additionally, the ZyXEL WRE2205 v2 offers an LED light to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy your high-speed wireless network throughout your home in minutes.
Set up your secured wireless network easily
The ZyXEL WRE2205 v2 uses a WPS button and an easy setup wizard feature to connect and extend your access point. It takes only a click of a button to set up a secured wireless network throughout the house.
  • Expand wireless coverage easily
  • Compact wall-mount design for convenient deployments
  • Set up your secured wireless network easily
  • Online firmware upgrades service
    The ZyXEL WRE2205 v2 provides an online firmware upgrade service so you can easily improve your device as enhancements become available. Stay up-to-date with the latest firmware for the optimal performance.
  • Energy efficient
    The ZyXEL WRE2205 v2 includes an on/off switch so you can power it down when not in use to save money.
Zyxel WRE2205 v2 - Wi-Fi range extender - Wi-Fi
External
United Kingdom
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
4.6 cm x 7.1 cm x 7.3 cm
85 g
4.6 cm
7.1 cm
7.3 cm
85 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Status Indicators
Power, signal strength, LAN, wireless, WPS
Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2 dBi
1 x 100Base-TX - RJ-45
1 x network cable
FCC, LVD
Internal power supply
3 Watt
10 - 90% (non-condensing)
