802.11n technology for extreme performance and coverage
The ZyXEL AMG1202-T10A featuring 802.11n technology provides the ultimate solution for speed and coverage. With data rate of up to 150 Mbps, the AMG1202-T10A provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11b/g Wi-Fi certified device.
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall security
The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, the AMG1202-T10A provides the first-line defense against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
The AMG1202-T10A comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
TR-069 remote management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "plug-and-play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
The ZyXEL AMG1202-T10A featuring 802.11n technology provides the ultimate solution for speed and coverage. With data rate of up to 150 Mbps, the AMG1202-T10A provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11b/g Wi-Fi certified device. -
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code. -
The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, the AMG1202-T10A provides the first-line defense against hackers, network intruders and other harmful threats. -
The AMG1202-T10A comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users. -
- Zyxel AMG1202-T10A - wireless router - DSL modem - 802.11b/g/n - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, READSL
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- Capacity
- Simultaneous NAT sessions: 2048
- PPTP, IPSec, PPPoE
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
- NAT support, VPN support, DoS attack prevention, packet filtering, ALG support, dynamic DNS server, manageable, IPv6 support, VPN passthrough, URL filtering, Access Point operational mode, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, port forwarding, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- 17.5 cm x 11.7 cm x 3.1 cm
- 200 g
- Localisation
- United Kingdom
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- Capacity
- Routing Protocol
- Encryption Algorithm
- MD5, 128-bit WEP, 64-bit WEP, TLS, TTLS, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, FCC, RoHS
- Status Indicators
- Port status, power, WLAN, WAN, LAN
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex L
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- Internal
- Antenna Qty
- 1
- Gain Level
- 3.5 dBi
- Power Device
- External power adapter
- Localisation
- United Kingdom
- 17.5 cm
- 11.7 cm
- 3.1 cm
- 200 g
- 0 °C
- 40 °C
- 20 - 85% (non-condensing)
