Zyxel VMG1312-B10D Wireless N VDSL2 4-port Gateway with USB
Quicklinx: BW64WS00 Mfr#: VMG1312-B10D-EU02V1F
The ZyXEL VMG1312-B Series Wireless N VDSL2 4-port Gateway with USB supports Vectoring technology to eliminate crosstalk or interference among different VDSL lines. In the mechanism, Vectoring significantly increases bit rates to compete with cable/fiber technology as well as to enlarge service coverage without changing the current infrastructure - a way to significantly save cost comparing to fiber-to-the-home (FTTH) deployments, while the CAPEX can be optimized by improved data rates and coverage without upgrading equipment. 2.4 GHz 11n (2x2) for superior performance and coverage.
Zyxel VMG1312-B10D - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Maximum number of configured SSIDs: 4 , ACL rules: 32
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, PPPoE, PPPoA, ARP
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, TFTP, SSH, CLI
Firewall protection, VLAN support, Syslog support, SPI, DoS attack prevention, packet filtering, URL filtering, parental control, firmware upgradable, ACL support, QoS, WPS, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, reset button, DHCP relay, DHCP client, NTP time synchronisation, CoS, DSCP support, SRA, Rom-D support, scheduler
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
15.8 cm x 11.45 cm x 2.2 cm
186 g
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
IGMP
Encryption Algorithm
128-bit WEP, 64-bit WEP, TLS, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, FCC
Status Indicators
Power, WLAN, LAN, USB, WPS, Internet, DSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.993.5
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
2
10.4 watt
Europe
15.8 cm
11.45 cm
2.2 cm
186 g
20 - 95% (non-condensing)
