Zyxel VES1724-55C VDSL2 DSLAM, 17a board-level vectoring STANDARD
Quicklinx: BW6FWS00 Mfr#: VES1724-55C-EU01V1F
The VES1724 conforms to G994.1 and to ensure the interoperability with standard-compliant VDSL CPE. The VES1724 supports 30a profile with 100 Mbps in both upstream and downstream traffics. With two Gigabit combo ports to connect upper layer aggregation networks, the VES1724 can support low-concentration interconnection from the subscriber ports to the network interface ports.
  • Robust connectivity
    Equipped with VDSL2, ADSL2+, and Gigabit Ethernet, the Zyxel VES1724-55C ensures high-speed wired connectivity for efficient data transmission and Internet access.
  • Comprehensive environmental adaptability
    Designed to operate in a wide range of temperatures from -40°C to 65°C and humidity levels from 10 to 95% (non-condensing), making it suitable for various operating environments.
  • Advanced management features
    Supports SNMP, CLI, and RMON for remote management, alongside features like IGMP snooping, IPv6 support, and Quality of Service (QoS), ensuring optimal network performance and ease of management.
  • Durable and compliant
    Meets multiple compliance standards including EMC, EN 55022 Class A, and RoHS, ensuring reliability and safety in its operations.
  • Energy-efficient design
    With a power consumption of only 63 W and a fanless design, it offers an energy-efficient solution for network setups, reducing operational costs.
Zyxel VES1724-55C - DSL modem
DSL modem - Ethernet
Rack-mountable
Max Transfer Rate
100 Mbps
Digital Signaling Protocol
VDSL, ADSL2+, VDSL2
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.997.1, ITU G.993.2, ITU G.998.4
Gigabit Ethernet
AC 120/230 V
44 cm x 25 cm x 4.435 cm
4.7 kg
DSL modem
Rack-mountable
Built-in Devices
POTS splitter
Modem
Bus
Ethernet
Wired
Max Transfer Rate
100 Mbps
VDSL, ADSL2+, VDSL2
Gigabit Ethernet
Remote Management Protocol
SNMP, RMON, CLI
IGMP snooping, IPv6 support, firmware upgradable, Quality of Service (QoS), fanless, Multicast VLAN Registration (MVR), Generic VLAN Registration Protocol (GVRP), Link Aggregation, Management Information Base (MIB) II
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP)
24 x VDSL2 - RJ-21 , 24 x phone line - RJ-21 , 2 x 100Base-TX - RJ-45 , 2 x 1000Base-T , 1 x management - RJ-45 , 1 x RS-232 (management) - DB-9
ETSI, EMC, RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 A, ITU-T K.20, ETSI 300 019, EN 55022 Class A, UL/CSA60950-1, ETSI 300-386
AC 120/230 V
63 Watt
44 cm
25 cm
4.435 cm
4.7 kg
-40 °C
65 °C
10 - 95% (non-condensing)
