Zyxel USG Flex Firewall 10/100/1000, 2*WAN, 4*LAN/DMZ ports, 1*SFP
Quicklinx: HHZ4WS00 Mfr#: USGFLEX200-EU0101F
£530.09 ex VAT
£636.10 inc VAT
ZyWALL USG FLEX series not only can protect your network, but it also support hospitality features including hotspot, AP management, and concurrent device upgrade.
  • Work remotely and securely
    As demands for remote access and work from home has increased, USG FLEX offers IPsec, SSL or L2TP-based VPNs to provide flexible secure network options for many of the common operating systems. Zero-configuration remote access reduced complicated setup challenges.
  • Uncovers threats
    Zyxel keeps learning from collecting threat information. USG FLEX series supports advanced anti-malware with cloud query express mode which expands billions of signatures. The cloud query with high detection rate helps verify the file hash within seconds.
  • Multi-layered protection
    USG FLEX is designed with multi-layer protection against multiple types of threats from in and out. URL threat filter, anti-malware, and intrusion prevention block external attacks, while application patrol and web filtering empower you to restrict users' inappropriate application usage or web access, all together safeguarding your network without any unattended gaps.
Zyxel ZyWALL USG FLEX 200 - firewall
Firewall
Rack-mountable
Europe
Performance
Firewall throughput: 1.8 Gbps , VPN throughput: 450 Mbps , Intrusion detection and prevention throughput: 1.1 Gbps , Antivirus throughput: 570 Mbps , Unified Threat Management (UTM) throughput: 550 Mbps
Concurrent TCP sessions: 600000 , Concurrent IPSec VPN tunnels: 100 , Concurrent SSL VPN users: 60 , Virtual interfaces (VLANs): 16 , Concurrent logins: 200 , Manageable access points: 8
Rack mount kit
27.2 cm x 18.7 cm x 3.6 cm
1.4 kg
Firewall
27.2 cm
18.7 cm
3.6 cm
1.4 kg
Europe
Rack-mountable
Wired
Network / Transport Protocol
L2TP, IPSec, SMTP, POP3
Routing Protocol
OSPF, RIP-1, RIP-2, BGP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Performance
Status Indicators
Power, system
Firewall protection, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, fanless, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
4 x 1000Base-T - RJ-45 (LAN / DMZ) , 2 x 1000Base-T - RJ-45 (WAN) , 1 x - SFP (mini-GBIC) , 2 x USB - Type A , 1 x console - DB-9
Rack mount kit
MTBF
529,688.2 hour(s)
CSA, ICSA IPSec certified, ICSA Firewall certified, VCCI Class B ITE, ICSA Antivirus, CSA 22.2 No. 60950, C-Tick Class B, FCC Part 15 B, EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE
External power adapter
13.3 Watt
Shipping Width
42.7 cm
Shipping Depth
24.7 cm
Shipping Height
7.3 cm
Shipping Weight
2.42 kg
10 - 90% (non-condensing)
Brand: Zyxel
Price Range Ex VAT: £500 - £750
