Zyxel USG 300 For 50-75 User 7GigEth
FREE 3 YEAR NBD REPLACEMENT WARRANTY
Quicklinx: 5GJSWS00 Mfr#: 91-009-034001B
ZyWALL USG 300 is a Unified Security Gateway that integrates comprehensive enterprise-class security features tailored for SMB (Small and Medium-sized Businesses). With streamlined integration of both IPSec VPN and SSL VPN technologies, the ZyWALL USG 300 is an ideal solution for organizations requiring intensive VPN applications across distributed networks. No matter you are in a remote branch office or at an unreliable hotel hotspot, the ZyWALL USG 300 can establish secure communication tunnels with IPSec and/or SSL protection. Another benefit of the integration is that the user-aware access control, scheduling, bandwidth usage and anti-threat security features can be enforced against inbound and outbound traffics of the protected network resources.
Zyxel ZyWALL USG-300 - security appliance
Security appliance
RAM
256 MB
Flash Memory
256 MB
Performance
Firewall throughput: 200 Mbps , VPN throughput (3DES/AES): 100 Mbps
Concurrent sessions: 60000 , IPSec VPN tunnels: 200 , VPN tunnels: 10
43 cm x 20.1 cm x 4.2 cm
2.8 kg
5-year warranty
Security appliance
43 cm
20.1 cm
4.2 cm
2.8 kg
Processor / Memory / Storage
RAM
256 MB
Flash Memory
256 MB
Wired
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS
Communication Mode
Full-duplex
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, auto-negotiation, load balancing, LDAP support, auto-uplink (auto MDI/MDI-X), Syslog support, traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, ALG support, dynamic DNS server, manageable, Intrusion Detection System (IDS), E-mail alert, antivirus analysis, High Availability, Intrusion Prevention System (IPS), URL filtering, firmware upgradable, DDos attack prevention, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications, IPSec passthrough
Encryption Algorithm
DES, Triple DES, MD5, AES, IKE, SSL, DH, SHA-1, PKI
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory
IEEE 802.1Q, X.509
Expansion Slots
2 (total) / 2 (free) x expansion slot
7 x 1000Base-T - RJ-45 , 1 x management - DB-9 , 1 x RS-232 - DB-9 , 2 x USB - Type A
Rack Mounting Kit
Included
FCC Class A certified, CSA, ICSA IPSec certified, ICSA Firewall certified, VCCI Class A ITE, CSA 22.2 No. 60950, EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, C-Tick Class A
35 Watt
Limited warranty - 5 years
50 °C
20 - 95%
