The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device.
Standard-based design assures compatibility
The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies. -
Hot-swappable design facilitates network maintenance
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device. -
Bi-directional transceivers maximizes usage of existing fiber plant
Traditional fiber optic networking requires two strands of fiber to accomplish communications, in which one strand is reserved for sending signals, while the other is for receiving. On the other hand, bi-directional, dual-wavelength transceivers can establish communications over just one strand of fiber by using two separate optical wavelengths: one receives and the other transmits signals. Transmission capacity can be expanded immediately without additional cost laying fiber. -
Supporting Digital Diagnostics Monitoring Interface (DDMI) SFP enhances management capability
The enhanced digital interface enables a real time link to be established between the switch and the SFP transceiver. This enables the switch to access operating parameters within the fiber link. This includes digital features such as soft control and monitoring of SFP I/O signals.
- Zyxel SFP10G-LR - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- 1.48 cm x 5.65 cm x 1.185 cm
- 20 g
- 5-year warranty
- Designed For
- Zyxel GS-1524, XGS1910-24, XGS1910-48; Dimension ES-1528, ES-1552, GS-1524
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10GbE
- 10 Gbps
- 1310 nm
- 10 km
- Hot swap module replacement, Digital Diagnostics Monitoring Interface (DDMI)
- 1 x Ethernet 10GBase-LR - LC single-mode x 2
- Compatible Slots
- 1 x SFP+
- TUV, Laser Class 1, FCC CFR21 Part 1040, FDA, MSA
- 1.48 cm
- 5.65 cm
- 1.185 cm
- 20 g
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Designed For
- Zyxel GS-1524, XGS1910-24, XGS1910-48 , Zyxel Dimension ES-1528, ES-1552, GS-1524
