Zyxel SCR CLOUD Router - 4*GbE LAN, 1*GbE WAN, Tri-Band WiFi 6E
Quicklinx: HHZ3WS00 Mfr#: SCR50AXE-EU0101F
£132.59 ex VAT
£159.10 inc VAT
SCR 50AXE is an entry-level router firewall, designed for SOHO/small business, integrated with best-in-class security, and easy management with the Nebula cloud.
  • Threat management
    Tackle against ransomware, block intrusion/exploit/dark web/ads/VPN proxy and stopping mail fraud and phishing.
  • Traffic management
    Traffic management helps you see how endpoint devices behave on your network; identifying applications that are traversing your network and usage of these applications.
  • Country restriction
    Identifies the country of origin of incoming traffic by examining its IP address. If the country is one you've chosen to filter, the SCR 50AXE denies access-protecting your network.
  • Easy to use app for everyone
    With a few simple clicks, your devices will be up and running in minutes. Nebula mobile app easily gets your SCR 50AXE's Wi-Fi and security features running without requiring you to have any networking knowledge.
  • Fast and efficient with optimized Wi-Fi 6E
    The SCR 50AXE's tri-band Wi-Fi operates concurrently to boost wireless network speed of up to 5.4 Gbps. Thanks to the 6GHz band with super-wide 160 MHz or 80MHz split channels, delivering maximum speed to multiple connections simultaneously with low latency.
  • At home, in the office, it's all just connected
    Nebula Cloud Networking solution allows you to just connect, protect, and manage the SCR 50AXE and other Zyxel's compatible appliances with the centralized cloud platform, Zyxel Nebula.
  • Guest access, made easy
    With Guest Wi-Fi, you can create a separate network for your guests to use, keeping your main network private and secure. No more sharing your personal WiFi password with strangers or worrying about them accessing sensitive information on your network. This can be set up in a few simple steps and protects your business network from outside access.
  • Simple WFH VPN setup
    Build secure tunnels for Work-from-home users to extend the working experience easily and securely. The SCR 50AXE's Site-to-site VPN keeps your home office securely connected without any complex VPN configuration steps.
  • See more, protect more
    Informative security dashboard presents status quo of the security level and analytics of threat events.
Zyxel SCR 50AXE - wireless router - Wi-Fi 6E - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
Frequency Band
2.4 GHz / 5 GHz / 6 GHz
Data Transfer Rate
5400 Mbps
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 2400 Mbps , Maximum data rate (6 GHz): 2400 Mbps , Firewall throughput: 900 Mbps , Threat management throughput: 900 Mbps
Recommended users: up to 5 , Maximum number of configured SSIDs: 4
Network / Transport Protocol
IPSec, PPPoE, DHCP, DDNS
Routing Protocol
IGMP, static IP routing
NAT support, auto-uplink (auto MDI/MDI-X), MAC address filtering, firmware upgradable, ACS, anti-malware protection, DHCP server, port forwarding, reset button, e-mail protection, DHCP relay, IP-MAC binding, DHCP client, cloud backup, IGMP proxy, cloud managed, MU-MIMO technology, domain filter, wireless intrusion protection, Guest VLAN, Explicit Beamforming, WPS button, ransomware protection, Dark Web blocker, ads block, VPN proxy block, GeoIP
6.82 cm x 17.8 cm x 24.22 cm
651 g
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
5400 Mbps
Performance
Routing Protocol
Encryption Algorithm
WPA2-PSK, WPA3-PSK
Authentication Method
Radio Service Set ID (SSID)
Wi-Fi Rating
AXE5400
BSMI, FCC
1 GHz
RAM
1 GB
Flash Memory
256 MB
Status Indicators
Status
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
21 Watt
Stand
1 x network cable
6.82 cm
17.8 cm
24.22 cm
651 g
Shipping Width
6.1 cm
Shipping Depth
24.6 cm
Shipping Height
30.35 cm
Shipping Weight
1.048 kg
10 - 90% (non-condensing)
Brand: Zyxel
