The ZyXEL SBG3300-N series applies ACL rules, Stateful Packet Inspection (SPI), Denial of Service (DoS) and DDoS features for first-line defense against hackers, network intruders and other harmful threats. A configurable DMZ provides more flexible accessibility while preventing external attacks on confidential databases.
The ZyXEL SBG3300-N series includes multiple WAN interfaces for DSL, Ethernet and USB 3G/4G adapters to establish WAN backups or load balancing. The WAN backup provides contingency in case the primary line or ISP suffers temporary outage. When the primary line of normal services is restored, all traffic resumes normal activity. This function enables highly reliable connectivity and flexibility in multiple applications.
The ZyXEL SBG3300-N series offers a two-level login mechanism to differentiate user segments. The ISP can also define the policies for the limited accounts to easily manage them with the integrated profile database.
- Zyxel SBG3300 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 300 Mbps
- Capacity
- Concurrent IPSec VPN tunnels: 20 , Simultaneous NAT sessions: 16000 , ACL rules: 256
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, FTP
- Routing Protocol
- RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, TR-069
- Firewall protection, DMZ port, NAT support, load balancing, Syslog support, SPI, DoS attack prevention, content filtering, dynamic DNS server, MAC address filtering, IPv6 support, DDos attack prevention, WMM support, ACL support, QoS, IPSec passthrough, Wireless Guest Services, VPN failover, WAN failover, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, port forwarding, DHCP relay, 3G/4G USB Dongle Support, DHCP client, NetUSB support, dual firmware images
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
- 21 cm x 11.5 cm x 3.3 cm
- 495 g
- Localisation
- Europe
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 300 Mbps
- Capacity
- MAC Address Table Size
- 2014 entries
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, TLS, SHA-1, TTLS, TKIP, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, FCC Part 15 B, IEC 60950-1, EN 60950-1, VPNC certified
- Status Indicators
- Power, WLAN, WAN, LAN, USB, ADSL
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.993.1, ITU G.993.2, ITU G.992.5 Annex A
- Max Transfer Rate
- 100 Mbps
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 3 dBi
- Power Device
- External power adapter
- 18 watt
- Localisation
- Europe
- 21 cm
- 11.5 cm
- 3.3 cm
- 495 g
- 0 °C
- 40 °C
- 20 - 95% (non-condensing)
